Trunck status problem
Discussion in '3CX Phone System - General' started by bullan, Apr 25, 2010.
  1. bullan
    Apr 25, 2010
    21
    I have a strange problem with trunck status:
    I have 4 SIP providers 3 of them I am able to register , one not.
    from the 3 registered 2 are shown in trunck status window (red dot) as not registered and one is shown as registered (green dot).
    I can make and receive calls on all 3 registered truncks and the status change in ringing and in call (orange dot) but at the end of the call not registered is shown.
    The third trunck works as it should.
    Tho 4th one (the not registered one) is shown as not registered (obviously) :)
    10,375
    231
    Restart 3CX, then have a look at the 3CX sever logs. All of the trunks should have tried to register right after the restart, you might get a clue as to what is happening. Post the logs if you still have questions.
  3. bullan
    Apr 25, 2010
    21
    oh yes
    actually Restart service solved the trunks status display; all are showed as registered with a green dot.
    the trunks was registered before, in log had registration succeed and I was able to make and receive calls, only the status display was wrong.
    anyway, problem solved, for the moment, thank you
    PS: stay tuned I'll have others soon :)
