Trunk DID's
Discussion in 'Ideas' started by 3t, Feb 6, 2017.
Trunk DID's 3.7 5 3votes
3.7/5, 3 votes
Tags:
  1. 3t
    3t
    Feb 24, 2015
    I have to add a lot of numbers (DID's) in my trunk.
    I don't find (and 3CX support confirm it dosen't exist) a way to create them all easly (import or other way to do that) as for the inbound rules.
    In Switzerland (i don't know for other countries) we can buy numbers by 1, 10, 100, 1000 all numbers are following in the "Range".
    So if there is a way to Import using a CSV or a button where you type the first number and select the Range that would simplify the creation in the Trunk.
    You imagine if we had to create 1000 consecutive numbers without an error???
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Importing Inbound Rules will add the DID to the list for that provider.
    Add 1 of the DID #'s.
    Goto Inbound Rules - setup the rule for that number.
    Now EXPORT that CSV.
    Open the CSV in Excel.
    Modify it to your hearts content.
    (A1+1 is your best friend. It will just keep adding 1 to the previous line.)
    Save It.
    Goto Inbound Rules - import that CSV.
  3. cel
    cel
    Jul 15, 2015
    34
    23
    I have created a similar thread, "DID/DDI Flexible Mapping", I would like that the system looks for an existing number first, extension, ring group or queue. So that you need not to spent to much time in inbound rules.
