Trunk marked as down, even though it's up
Discussion in '3CX Phone System - General' started by danoh, Jun 6, 2011.
  1. danoh
    Aug 18, 2010
    56
    I have 3 sip trunks. Trunk 1 and 2 show as up (green dot), while trunk 3, even though it's registered, shows as down (red dot)
    Trunk L:10010(VWT SIP 3) has changed status to registered.
    I have not restarted the phone system, as it's not feasible for me to restart it at this time due to usage... nor would I think I would have to restart it to make 3CX see this trunk as a "green dot"
    I can make calls out and in on the trunk. The trunk is configured to only allow outbound and inbound calls when registered. So, obviously, 3CX knows it's registered.
    Maybe just a display bug on the "Ports/Trunk Status" screen and also the "Remote connections" screen??
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    open the 3CX Console
    goto > VoIP Providers. single left click the provider which is showing down, and click Refresh Registration
  3. danoh
    Aug 18, 2010
    56
    I've done that a few dozen times :(
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could You please specify name of Voip provider (link to website)?
  5. danoh
    Aug 18, 2010
    56
    Broadvoice - http://www.broadvoice.com
    Yes, it's not on your "approved" list, but it works great - just 3CX thinks it's unregistered.
    For what it's worth, the other 2 trunks that are correctly shown as registered with a green dot are also Broadvoice.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    141
    Sometimes this might happen. - under very rare conditions. provider will be registered but update will not be received for registration. This is just an interface issue and functionality will not be affected.
    try to restart the services. If it still shows as red another option is to delete the provider and re-create it again.
    This should fix the problem.
