Trunk provider requires Diversion Header
Discussion in '3CX Phone System - General' started by pehavel, Jun 8, 2017.
  1. pehavel
    May 31, 2017
    6
    I have a problem displaying the correct original caller's number for an outgoing call from 3CX, when call is redirected.
    I have consulted this problem with the trunk provider: They need in SIP packet header Diversion field.
    How can I set 3CX system to sent this Diversion Header for outgoing redirected call? I have not found this option anywhere.
    Thank for help.
  2. StefanW
    Jun 2, 2009
    1,222
    93
    there is a small issue with this header, even widely used it is "Historic"
    https://tools.ietf.org/html/rfc5806
    and has been replaced with the history header... Best to switch to a supported provider which does not need this.
  3. pehavel
    May 31, 2017
    6
    When Diversion Header is history (old), what is now use for redirected signaling in SIP?
  4. StefanW
    Jun 2, 2009
    1,222
    93
    As stated the "history header". But in general, most providers only require that you send a number you own (as authorization) and the number you like to show (display number).
