Trunk with multiple DID numbers
Discussion in '3CX Phone System - General' started by jloper, Sep 28, 2010.
  1. jloper
    Sep 28, 2010
    5
    I am trying to install and use the free version of 3CX. I am using Vitelity as my VOIP provider. I was able to get the trunk working, however, I can only get one DID to terminate successfully.
    The Phone number that I put into 'external number' field on the General Tab of the VOIP provider is carried down to the 'PORT Identification' field on the PORT Tab. This Phone number works and I can accept an inbound call. All the other DID numbers will not terminate. If I change the TN to another number, again that single DID will terminate.
    To me it makes no sense that the PORT created looks like a DID [that is you have to specify which extension to terminate the inbound calls to]. I would think I could specify the User ID and password, my SIP server and the number of simultaneous calls, and then setup any number of DID's with inbound rules.
    The verbiage on the configuration page for the VOIP provider uses the term 'Line' in several places. This is not supposed to be line, but a trunk, in fact in my case it can carry 10 simultaneous calls.
    How do I configure a Trunk, and not a Line ? How can I get 3CX to monitor the trunk for any number of DID numbers?
    John Loper
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Hello John,
    For the DDIs on the edit voip provider page, select the source tab. Tick source identification by DID, then add the DID numbers. Is that helpful?
    Kind regards
    Richard Crabb
  3. jloper
    Sep 28, 2010
    5
    Yes Sir. This did help. Now the DID numbers ring into the PBX and are forwarded to the correct extension.
    Thanks,
    John
  4. bbeaty
    Jul 18, 2011
    I am having a similar issue.
    I have 200 (8000 - 8199) numbers coming in from a VOIP GW into 3CX. How can I get 3CX to send the call to the correct location (phone, Auto Attendant, Ring group, etc) based on the incoming dialed number instead of having to touch each individual DID number and specify the extension number to terminate to?
    Nothing I have tried works, I end up having to add the DID numbers and then edit each one individually. Default settings sends everything to a main number. It creates an incoming rule for each number, plus the ruling under the VOIP provider.
    Mark Jones likes this.
  5. willow
    willow Member
    Mar 1, 2011
    471
    you will have to touch each one.
