Trusted certificate and domain.
Discussion in '3CX Phone System - General' started by hogan71088, May 24, 2016.
  1. hogan71088
    Nov 30, 2015
    62
    Hi All,
    If you were setting up a new customer that needed a trusted certificate to use webrtc, would you just simply buy a new domain, set an a record to point at the public IP of the PBX and then link the cert to the domain name?
    IIS will not be used in this case.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    If you are setting a new PBX installation then yes, you must get a new domain specific for the PBX and set an A record in the DNS to point to the PBX installation. IF your client needs a trusted certificate to use WebRtc then you get one and import it when the 3CX installer asks you to.
    Please note that WebRtc works with a 3CX self signed certificate that can be generated during the installation process.
