try a 16 lines Pro version, after trial conver to to permanent license?
Discussion in '3CX Phone System - General' started by nobody, Mar 2, 2018.
  1. nobody
    nobody New Member
    Aug 15, 2017
    146
    6
    The title says it all.
    If I use the (one year) trial version, can convert this after the sucessful trial to a permanent license?
    TIA
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    16 call standard.
  3. nobody
    nobody New Member
    Aug 15, 2017
    146
    6
    I need the Pro features tapi, crm integration, wallboard.
    a 30 day trial would be enough.
  4. bnc1
    Jul 29, 2009
    No problem, just contact your local 3CX partner.
    3CX partners can give you a 30 day pro licence for testing.
