Try out the latest Android Update in BETA
Discussion in 'Android' started by Bianca, May 17, 2018.
  1. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,395
    78
    jed likes this.
  2. 12494
    12494 Member
    Apr 16, 2010
    280
    18
    I just installed 15.5.342 although the changelog says .341 is latest.
    I had a couple issues immediately after installing.
    If my phone was locked and a call came to my extension the call went immediately to VM instead of ringing phone.
    I then tried to use the app to change my status and I was not able to change status - status remained the same.
    Regards,
    Allen
  3. LeonidasG
    Nov 19, 2008
    1,395
    78
    I'm trying it here and it seems to work for me.
    Switching to a different status other than "Available" requires tapping it twice. We plan to change this in the final release.
    In your case was the double tapping the problem?
    jed likes this.
  4. 12494
    12494 Member
    Apr 16, 2010
    280
    18
    Thanks. I wasn't doing the double tapping very well. Works now.
    Allen
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,376
    52
