Try to transfer call - if not successfull transfer to other number
Discussion in 'Call Flow Designer' started by Mini25, Sep 21, 2017.
  1. Mini25
    May 28, 2014
    I'm designing a new CFD App and I have a problem. I want to transfer a call to a phone number for example for 20sec. If nobody is taking the call it should be trasfered to another number.
    How can I achive this in Call Flow Designer?
    It would be gread, if there is a solution.
    Best regards
    Mini25
    #1 Mini25, Sep 21, 2017
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hi @Mini25,
    From the Call Flow Designer calls are always blindly transferred, and as soon as you transfer the call, you lose control over it. The only way would be to configure a "Destination if no answer" for the extension where you're transfering the call the first time...
    Kind regards.
