Trying manually provisioning Aastra 5370ip Phone
Discussion in '3CX Phone System - General' started by Joe_San, Dec 5, 2017.
  1. Joe_San
    Dec 4, 2017
    I'm trying to get a Aastra 5370ip Phone to work with 3CX. The server is running on the server vlan and the phone is in the client vlan.
    The only option in the phone menu that I get and changed are.:
    DNS_Server *changed to DNS server ip*
    PBX_Address *changed to the 3CX Server ip*
    SIP_Port_PBX *changed to 5060*
    SIP_Port_Phone *changed to 5060*
    User_Phone_Number *changed to auth.-id*
    User_Password *filled in the extension pasword*
    But I still get registration failed on the Phone.
    Kind regards,
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,325
    221
    With vlan setting, can the phone vlan connect to the server vlan
    On the extension, has you unticked 'Disallow use of extension outside the LAN' on the option tab within the console.
  3. Joe_San
    Dec 4, 2017
    Thanks for your replie
    The phone and server vlan can connect both ways.
    Yes, I unchecked the 'Disallow use of extension outside the LAN' within the extension settings on the 3cx management console.
  4. n2
    n2
    Nov 8, 2010
    16
    The fields you mention do not seem to be the same as that for Aastras that I have.
    In the line 1 configuration -
    Phone number = extension number
    Authentication name = authentication ID (may be extension number or 3cx generated depending on version)
    Password = Password
    Proxy server = 3CX IP
    Proxy port = 5060
    Registrar server = 3CX IP
    Registrar port = 5060
    You may also need to check and see if the phone IP got blacklisted in the meantime and if so....remove.
  5. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
    Do you see any registration attempts in the PBX log? Is the phone IP blacklisted by any chance?
