Trying to add SIP URI Parameter
Discussion in '3CX Phone System - General' started by Kobberhjelmen, Aug 14, 2017.
  1. Kobberhjelmen
    Aug 1, 2017
    11
    I have a sip provider that requires an URI Parameter of "user=phone".
    I'm trying to add this by setting the outbound "Request Line URI : Host Part" to Custom Field variable, and adding the following Custom Value: "IP:5060;user=phone" - But the part after ; gets ignored, and isn't in my wireshark capture.
    Is it not possible to create/add a SIP URI parameter in 3CX?
    10,366
    227
    Is anything other than user=phone actually required?
  3. Kobberhjelmen
    Aug 1, 2017
    11
    IP+Port is needed, user=phone is a "secondary" parameter, but at this particular provider it is required
  4. leejor
    10,366
    227
    I came across this.
    https://www.voip-info.org/wiki-sip+uri
    It mentions the use of the @ , and the correct format.
    I'm not certain it is what you are looking for. Just sounds like the information you are putting in, may be more that can be accommodated, and therefore ignored, or in the wrong format.
    #4 leejor, Aug 15, 2017
  5. Kobberhjelmen
    Aug 1, 2017
    11
    before @ is the user part (number), after @ is the host part (server+port), i need to add the uri parameter to the host part - This is normally done by putting semicolon+"uri-parameter" (;user=phone in this case), but perhaps i need a different syntax for 3CX, since it is getting ignored.
    But i cant find anywhere if they support, or doesn't support uri-parameters, so that could also be the reason.
    If a create a CustomField with a Custom value, i can put in user=phone as the only value, and the entire uri turns in to: sip:number@user=phone:5060.
    If i makes the custom value 1.2.3.4:5065 (Different host ip+port) it turns in to sip:number@1.2.3.4:5065
    If i makes the custom value 1.2.3.4:5065;user=phone it turns in to sip:number@1.2.3.4:5065
    Thats why i think 3CX either doesn't support uri-parameters,or i need a different syntax than ; to activate it
