Trying to establish CSTA session to...
Discussion in '3CX Phone System - General' started by complex1, Jun 8, 2017.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    I am now on v15.5 and every minute or so I receive a “Trying to establish CSTA session to <sip:xxx...” message in the Activity Log, because not all phones support the uaCSTA feature.
    I use a mix of W52P, W56P, T48G, N300A and Linksys ATA’s.
    For monitoring function the logging level is set to Medium and I don’t want to set it to Low.
    Is there a way to suppress this messages from the devices that do not support the uaCSTA feature?
    Thanks for the help.
  2. StefanW
    Jun 2, 2009
    1,222
    93
    no, as this an medium error warning from the pbx that something failed. As in this case it is expected to fail as those devices do not support it it is arguable if they should be suppressed. But the answer for the time being is no.
