trying to get 3cx to dial
Discussion in 'Android' started by slowjam1969, Mar 13, 2011.
  1. slowjam1969
    Mar 13, 2011
    i have a htc hero sprint and downloaded andriod directly to phone.
    it says i have registered my voip acct and ext to the app but it says 111 @ my ip for virtual pbx i have
    it has number i dialed but no dial
    it says on hook and available
    not sure what problem is
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    are you registering to 3cx pbx or directly to a voip provider?
  3. leejor
    11,105
    329
    If you are trying this through 3G, try getting it to work first though WiFi. If that works, then move on to 3G. If it still won't work over 3G then it may be a "provider issue".
  4. sinoquebec
    Mar 4, 2011
    10
    can you give us a 3cx version for Android 2.3.3? The current is not working.
  5. leejor
    11,105
    329
    We can hope that the next release, whenever it comes out, will be written to work with the new Android version.
