trying to keep alive
Discussion in 'Android' started by marc.palmer, Jun 30, 2010.
  1. marc.palmer
    Jun 30, 2010
    6
    i have have found it very straitforward to register my lg ally 'droid' phone to my 3cx pbx, but I would like to keep the connection alive. Unless my lg ally is hooked to its power adapter, it looses the registration after a few minutes. Any suggestions?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Sorry, but it is slightly uncear.
    Do you use 3CXPhone for Android or you have problem to register other SIP phone on 3CX PBX?
  3. marc.palmer
    Jun 30, 2010
    6
    Sorry, It is the 3cx phone for android.
  4. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Is it possible that you are using WiFi and there is a power-saving mode in the Ally? Did you check the "Lock WiFi" setting in Integration settings? It should be on.
