Trying to plan out a VM server, whats the smallest VM 3cx debian will support
Discussion in '3CX Phone System - General' started by sean.suntelnetworks, Feb 10, 2017.
  1. sean.suntelnetworks
    Oct 10, 2014
    34
    Just trying to plan out the next VM server for our company. I know with Windows single instance, I was reserving about 40GB, (10 for OS, 5 for Apps, 10 for swap/temp storage/windows updates and 10GB for backups) but I'd like to see how many 3cx debian VMs I can squeeze in 500GB (w/o recording storage)
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Hello @sean.suntelnetworks
    If we are only discussing disk space then i am afraid only you can answer your question, as this depends on how large your installations will be, how large are your backups, how often you backup etc.
    The only thing i can advice is to always overestimate so you don't find your self having to change hard drives and un-installing and re-installing.
  3. sean.suntelnetworks
    Oct 10, 2014
    34
    Well, can you give me some baseline for say 25 extensions, 200 calls a day total. each 5 minutes in length. One call report generated a day, one backup a week, keep 5 backups.
    There's has to be a formula where your high profile clients are provided when planning out installs.
  4. YiannisH_3CX
    May 10, 2016
    4,381
    278
