trying to understand error codes
Discussion in 'Windows' started by viopnewbee, May 14, 2010.
  1. viopnewbee
    May 14, 2010
    I'm using just the 3cx phone download... I'm trying to setup the phone... followed instructions online and successfully got one profile working... tried to add a 2nd profile and got this error
    error: 401 - invalid pin
    and then I got
    error: 404
    what do these error codes mean?
    Basically, I need a point into the right direction...
    thanks ahead...
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Error 404 means not found.
    1. Check that you have entered the correct ip Address settings.
    2. Check that the username and password are correct.
    3. CHech that all ports are set correctly.
  3. viopnewbee
    May 14, 2010
