Trying to update to 15 sp1
Discussion in '3CX Phone System - General' started by hopandhide, Jul 29, 2016.
  1. hopandhide
    Jul 11, 2016
    If i press the update button on the dashboard I get the following 500 error. Please can anyone help?
    System.FormatException: Input string was not in a correct format.
    at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
    at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
    at ManagementConsoleJS.VersionStringComparer.CompareStatic(String x, String y)
    at ManagementConsoleJS.Firmware.get_OutOfDate()
    at ManagementConsoleJS.UpdateService.UpdateNotification(IEnumerable`1 list)
    at ManagementConsoleJS.UpdateService.<BuildListForUpdateAsync>d__15.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at ManagementConsoleJS.Controllers.UpdateCheckerController.<CheckForUpdates>d__4.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ObjectMethodExecutor.<CastToObject>d__40`1.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeActionFilterAsync>d__28.MoveNext()
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeAsync>d__18.MoveNext()
    at Microsoft.AspNetCore.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
    Ok
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,367
    535
    Hello there,
    Could you please try the following and let us know if ti works?
    Go to C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxxxx\firmware_new and edit the file firmwares.json
    Find C600 and C400 and remove the ".D" from the "ServerVersion" and "LocalVersion" if it is there. Save it and try again.
    Ideally if you have these models attached to your network unplug them for the update procedure.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    What I would like to add here is that you need to also restart Management Console Service.
    So after you remove .D and save, restart MC Service and try again.
