TTS Issue
Discussion in 'CRM / Helpdesk / App Integration' started by mv.ape, Jul 12, 2016.
  1. mv.ape
    Feb 16, 2015
    24
    I make a VAD that will check a credit in a database and then tell to customer using text to speech.
    I use a QueryResult and get the right value from database.
    In the text to speech I don't know why a the end it say "undefined": "Your credit is 5"... undefined.
    In debug mode I've check the value is good.
    TTS concatenate: 'Your credit' + $callflow.Credit
    Even if i try to replace $callflow.Credit by a fixed number
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,436
    114
    The problem is that $callflow.Credit is not a valid javascript expression. You need to use the CONCATENATE function instead. Please try with the following expression:
    CONCATENATE('Your credit', callflow$.Credit)
    Kind regards.
  3. mv.ape
    Feb 16, 2015
    24
    I already use CONCATENATE function.
  4. edossantos
    Jun 27, 2007
    1,436
    114
    Can you show exactly the expression used in your TTS prompt?
    You mentioned:
    which is not valid.
    You should use:
    CONCATENATE('Your credit is ', callflow$.Credit)
    and it should work as long as callflow$.Credit has the right value.
    How are you setting callflow$.Credit?
  5. mv.ape
    Feb 16, 2015
    24
    TTS Exp:
    CONCATENATE('Vous disposez de ticket de support, votre solde de ticket est de',callflow$.CreditTicket)
    In my test call:
    VARIABLE_CHANGED: AccueilSTechique_CreditTicket=5
    AccueilSTechique is the name of the callflow
    CreditTicket is declared in the callflow (R/W) with an initail value of 0.
    All work except the word "undefined" in the speech at the end
  6. edossantos
    Jun 27, 2007
    1,436
    114
    Thanks for sending the detailed explanation.
    I think that the problem might be the comma in the middle of your text. Can you please try with the following expression?
    CONCATENATE('Vous disposez de ticket de support votre solde de ticket est de',callflow$.CreditTicket)
    (removed the comma between "support" and "votre").
    Just to see if this makes any change.
    Thanks.
  7. mv.ape
    Feb 16, 2015
    24
    Many thanks that work when delete coma in TTS.
    So one question how to make "pause" instead of a comma?
  8. edossantos
    Jun 27, 2007
    1,436
    114
    That is a bug and needs to be fixed, but for now you need to use a different way.
    Have you tried with a period?
    CONCATENATE('Vous disposez de ticket de support. Votre solde de ticket est de',callflow$.CreditTicket)
