Tunnel Configuration
Discussion in 'Windows' started by HatchITMan, Apr 23, 2008.
  1. HatchITMan
    Dec 18, 2007
    18
    I use the Voip client from many different networks. The tunnel works very well, once the 'use tunnel of' field has been completed. If this is set to '127.0.0.1' it will change to the address found for the computer on the local network. When I move to another network the client will not connect, until the 'use tunnel' field is changed again.
    Is there a way round this that I have missed? If not, would it not be possible to add a tick box on the login page to say, "If using tunnel, then use the tunnel of this computer" which forces it to use the address that the computer has been allocated on the current network. Otherwise, could the '127.0.0.1' address be the signal that this is what I want to do?
    I am using Client 4492 with XP, a similar problem seems to occur with Vista.
  2. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    Same here. I'm always on the move and everywhere I go, I need to do the steps you told when I want to connect the soft phone. I also always use the "127.0.0.1" because it makes everything easier, but I always need to write it. I have not found a way to fix this.
    This problem is not OS related (I supose), since all tested OS did the same.
    It would be a nice idea to check this in the future versions and it would not be that hard to implement I think since all is needed to do, is to use the loopback IP "127.0.0.1" and the program automaticaly detects the IP.
