Tunnel Extension
Discussion in '3CX Phone System - General' started by brianjg, Nov 6, 2008.
  1. brianjg
    Nov 4, 2008
    10
    We have 3 remote sites with 2 users at each. I don't want to have a server in each location so instead I was planning on using a tunnel. My questions is do I need a separate extension for each tunnel or can 1 be shared between the 3 locations?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Do you will use 3CX VPN or Hardware VPN
  3. brianjg
    Nov 4, 2008
    10
    I plan on using the 3cx tunnel on a client pc to connect 2 SIP phones. There will be no VPN between sites.
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I do this with out tunnel
    you can connect your 2 sipphones directly using stun server like stun.fwdnet.net
