tunnel Functionality
Discussion in 'Android' started by andymars, Jun 21, 2010.
  1. andymars
    Jan 12, 2010
    47
    having tried this out it appears to work well, but i'm hoping that you will add the tunnel functionality like in the 3CXPhone for windows. Is this possible?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    HI
    Something we will def add and is currently on the roadmap. However first transfers.
  3. andymars
    Jan 12, 2010
    47
    no problem, thanks for letting me know :)
