tunnel ok, call go, mute who make call
Discussion in 'iOS' started by MasterX, Sep 6, 2012.
  1. MasterX
    Oct 2, 2008
    28
    hi, i installed 3cx on new server
    all ok
    i download iphone last version ; download 3cx tunnel , too.
    i open 5060 tcp and 5090 tcp port on my router
    on iphone, tunnel it's ok
    open app 3cx iphone , call go, ring in factory; who call listen , but who responde ask correctaly but not listen.
    there is other configuration o other port from open?
    thanks
    11,277
    360
    Did you read this post?
    http://www.3cx.com/forums/viewtopic.php?f=35&t=29057
  3. MasterX
    Oct 2, 2008
    28
    in this post there isn't my solution
    i open 9000-9048 port and it'ok
    bye
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Hi, try also this, it is rom 3cx blog:
    You should also perform port forwarding for port 5090 (TCP & UDP) to allow remote extensions to connect using the 3CX Tunnel Protocol.
