Tunnel Password Error in Assistant
Discussion in '3CX Phone System - General' started by megatech, Nov 4, 2009.
  1. megatech
    Oct 19, 2009
    14
    Hi There
    After setting and confirm operation of my 3cxAssistants I change the degault password of abc to Pxh_6789.
    I set the new password in the 3cx manager.
    The assistant will not connect. no other changes, just the password for the Tunnel
    I setup a 3cx Proxy with same setting and password and that connect fine. The problem is limited to 3cxAssitant only..
    cheers
  2. peterbunn
    Jun 3, 2009
    20
    Have you tried testing it with the softphone?
  3. leejor
    10,839
    297
    Have you tried a password without an underscore, just wonder if that is the problem?
