Tunnel Port
Discussion in '3CX Phone System - General' started by ceemour, Feb 14, 2008.
  1. ceemour
    Oct 30, 2007
    How do you change the 3cx phonesystem tunnel port from 5090 to ???
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    <3cx>\bin\3CXTunnel.ini:
    [Conn1]
    TunnelPort=xxxx
    and restart tunnel service after change
