- Joined
- Feb 9, 2012
- Messages
- 70
- Reaction score
- 9
With v10 the tunnel was working fine, with using an android 3cx client and also with the 3cx sip proxy manager.
Since upgrading to v11 the tunnel doesn't connect.
Here is log output from the sip proxy manager-
.\Bridge.cpp(188) : {15:12:52.628}(Log2):Connecting tunnel 'TunnelClient'(123456) to xxx.xxx.xxx.163:5090
.\TCPSide.cpp(32) : {15:12:52.628}(Trace5):Connecting to xxx.xxx.xxx.163:5090
.\TCPSide.cpp(38) : {15:12:53.810}(Trace5):Attempt to connect to xxx.xxx.xxx.163:5090 has failed
.\Bridge.cpp(199) : {15:12:53.810}(Log2):Failed to connect Tunnel 'TunnelClient'(123456) to xxx.xxx.xxx.163:5090
.\Bridge.cpp(201) : {15:12:53.810}(Trace5):$ Next connection attempt in 5590 ms
One thing I am aware of - 3cx server is running on Windows XP SP3 - I am aware this is no longer officially supported.
Before looking at anything else, does anyone know if the tunnel is broken when using Win XP?
I've already checked under the extensions that "disallow use outside lan" and "block remote tunnel" are not ticked.
Chris
Chris
