Tunnel Problems
Discussion in '3CX Phone System - General' started by bdronn, Sep 2, 2012.
  1. bdronn
    Sep 2, 2012
    I have been trying to connect remotely to extensions via android phone. for some reason the tunnel just doesn't work. can someone please help me?
    11,095
    327
    You need to provide a bit more information.
    If all else works correctly, then you should probably be posting in the Android forum and include the details of your phone make/model, etc.
    You also need to detail exactly what the issue is, as well as posting any relevant 3CX logs.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you tried to setup without the tunnel? You definitely need to post more about the issue.
