Tunnel working
Discussion in '3CX Phone System - General' started by beaver, Jun 28, 2009.
  1. beaver
    Aug 2, 2007
    30
    At last I have the tunnel working Yeah. Now does anyone have heard about a softphone for wm 6 that works with tunnel? and have tested it?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    What is "wm 6" ?!? :oops: :roll:
  3. sipero123
    Nov 24, 2008
    94
    Probably Windows Mobile 6.0
    Jonathan Hamon
  4. beaver
    Aug 2, 2007
    30
    yes is windows mobile 6. What we want to try is use cell phones with a voip aplication that can resolve via the tunnel. there are a lot of wm 6 softphones that works inside the net but until now i can't find one that works with a tunnel. Thanks for the help and atention.
