Tunnel ?
Discussion in 'iOS' started by axion1, Nov 16, 2010.
  1. axion1
    Nov 18, 2009
    10
    I have some audio issues like some others users with 3g connection, and i am wondering if you will integrate the 3cxtunnel in the app for the next version ? (not everyone can have a vpn so ...)
    Thank you
  2. StefanW
    Jun 2, 2009
    1,236
    96
    we will try to do this. it is on the roadmap but if it will work we dont know yet. Andriod will may have this first
  3. Geeg
    Jul 30, 2010
    5
    Unfortunately, this app is useless for me since I need the Tunnel to operate in this 3rd world country. I have been using iSip on the IPhone and routing it through a server running the Sip Proxy Tunnel but I can't even configure the 3cx app to do this? Guess I will just have to wait and see if 3cx adds this feature.
