Tunnel
Discussion in '3CX Phone System - General' started by AndreasMetal, Feb 24, 2008.
  1. AndreasMetal
    Nov 16, 2007
    62
    Hey again 8)
    Because I am not expert please, if you can, say me in a few words, how can I set a tunnel for ~5 users.
    Thanks!
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    It is not so hard.
    On 3CX server open port 5090 TCP and set tunnel password.
    On remote location install 3CX Voip client.
    Set up tunnel from 3CX Voip client to 3CX server.
    Set phones to use 3CX Voip client as proxy.
    This is a manual for the tunnel: http://www.3cx.com/support/3cx-tunnel.html
    I had to add :5080 to the proxy adress in the phone. (so repace 10.0.0.1 to 10.0.0.1:5080 in the manual)
  3. AndreasMetal
    Nov 16, 2007
    62
    Thanks 8) 8) 8)
    My problem is this: Public IP address of the 3CX Server site: 222.222.222.222
    Internal IP address of the 3CX Server : 192.168.0.1
    IP address of your remote PC that will act as proxy: 10.0.0.1
    IP address of the hard phone that will use the proxy:10.0.0.2
    Because I am not expert, where change I these settings and..in IP or FDQN what IP must I type.
    And last..how can Voip Client recognize who's 3CX Server is contacting ?
    thnks :mrgreen: :mrgreen: :mrgreen: :mrgreen:
  4. AndreasMetal
    Nov 16, 2007
    62
    Ehm..tunnel is available only in commercial versions?
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    i think so
  6. AndreasMetal
    Nov 16, 2007
    62
    Oh :cry: :cry:
    Thanks ;)
    btw..I use free version :cry:
  7. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Ah if that is the case then that will be why I can not get the tunnel to work, this should be made clearer. :cry:
    Stephen
  8. AndreasMetal
    Nov 16, 2007
    62
    Then..
    now I know 8)
    thanks
    8) :mrgreen: :mrgreen: :mrgreen: :mrgreen:
  9. matthijsolislagers
    140
    The tunnel is also available in free edition.
  10. matthijsolislagers
    140
    You don't need to change them. They are there for example.
  11. AndreasMetal
    Nov 16, 2007
    62
    Thanks, but I can't find the Tunnel and the other tabs nowhere in any way :shock:
    Thanks..but..
  12. Wardy
    Wardy New Member
    Sep 18, 2007
    110
  13. AndreasMetal
    Nov 16, 2007
    62
    Thanks!
    I found it :D:D
    these settings: # In the ‘Remote end of tunnel’ enter the Public IP address of the Remote 3CX Phone System.
    # In the ‘Use Tunnel of host’ enter the local ip address of the PC you are running the 3CX Phone Client on. (Note: as you enter this the field underneat is greyed out and locked.)
    # In the ‘Tunnel Password’ enter the password you set in step 1 of the previous section of this FAQ.
    are from http://www.3cx.com/support/3cx-tunnel.html..
    Use i these settings or the remote extension?
  14. AndreasMetal
    Nov 16, 2007
    62
    It is important..
    listen...
    In USE TUNNEL OF HOST writes my remote friend: 192.168.178.** and in port 5060 (that I add as "registrar") in the phones to connect with the local 3cx)
    In REMOTE END OF TUNNEL writes my current IP address: 79.***.7*.** and in port 5090.
    I forwarded port 5090 on my router,
    but nothing seems to be works :(
    eHM.... May the problem is that he hasn't SIP phone and he tries to speak with VoIP Client..?
    thanks..
  15. AndreasMetal
    Nov 16, 2007
    62
    Please answer,
    if anyone knows.
    Time is money :roll:
    thanks 8)
