Turn Off 486 - Busy here
Discussion in '3CX Phone System - General' started by johann_wnd, Oct 6, 2015.
  1. johann_wnd
    Sep 11, 2015
    is it possible to turn off the email notification for the trunk-event 486 - Busy here?
    it should be only this notification disabled. all other should work normally.
    anyone a idea?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Go to "settings" and then "general" and make your selection. Presumably you have the option checked for when a trunk encounters an error code. You can disable this one, but all error codes will be disabled as you cannot pick and choose. In most cases, I assume you wold only really want to know if the trunk status changes.
  3. johann_wnd
    Sep 11, 2015
    Hello Ineblett,
    thanks for your answer.
    is it possible to disable the notification only for this one error code?
  4. lneblett
    Sep 7, 2010
    2,083
    61
  5. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    In 12.X:
    Custom Parameters -> RESPONSE_ERROR_CODES (remove 486)
