Turn off the fax?
Discussion in '3CX Phone System - General' started by RobLloyd, Jan 15, 2008.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Is there a way to turn off the fax feature? I don't use it & my providor doesn't support it right now. I'd like to turn it off and not see those registration messages every 10 minutes.
  2. perm
    Dec 11, 2007
    You can stop the service in windows, it works fine :)
    /per malmstrøm
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Duh! Should have thought of that myself. I was thinking there should be a checkbox somewhere in the console to enable/disable faxing.
  4. colin2710
    Oct 29, 2007
    28
    Hi There,
    Thanks - was going to ask question <BIG GRIN>.
    May thanks - Regards Colin
