Turning Hold Music Off.
Discussion in '3CX Phone System - General' started by ipSkillz, Mar 25, 2007.
  1. ipSkillz
    Mar 21, 2007
    20
    Dear admins.
    I would like the option to turn hold music off.
    I have written my on-hold centre for software pabx's and I would like to use it, but whenever I press the hold option during a call, I hear my progam begin and then automatically your hold music kicks in.
    Is there a way that I can temporaily disable the built-in hold so I can continue testing my pabx answering software?
    Thanks in advance.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Music on hold is provided by our Media Server, so to make tests you can just turn it off in Services management console.
    Best regards,
