Turning off option "0" inside voicemail greeting
Discussion in '3CX Phone System - General' started by Jason Buffa, Jan 31, 2018.
  1. Jason Buffa
    Feb 13, 2017
    18
    I have searched these forums and have seen no good answer on turning off the "0" option while inside a voicemail greeting. This option is not mentioned to the caller, but people who get frustrated with getting a voicemail often hit 0 to try to get a real person. I'd be fine turning that option off, or if it can be re-directed on an ext-by-ext basis, even better. We don't want all calls to go to the operator with this option.
    Thanks!
    Jason
  2. Jason Buffa
    Feb 13, 2017
    18
    PS- I already edited the .wav file to remove the "press * to talk to an operator" portion of the default greeting but found out they can also press 0.
  3. leejor
    11,127
    330
    On many systems, the destination for a zero press can be configured differently on an extension by extension basis, or disabled. There may already be a feature suggestion in the ideas forum that can be up-voted, or you could make a suggestion yourself. I don't recall seeing anything about disabling it currently.
  4. Jason Buffa
    Feb 13, 2017
    18
    Oh yes, our previous system had this capability as well. I just wanted to make sure I wasn't missing something in 3CX somewhere.
  5. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    113
    20
    Dang, Jason... I thought I was so cute giving the operator an extension and leaving the "zero" operator extension as a "General Delivery Mailbox".
    I thought the IVR took care of that "dial 'zero' hole" you are grappling with. I also have this quandary that someone goes to any voicemail and drops to the "zero" voice mail by pressing "zero" during the outgoing message. Time to think... Ouch... Ouch...
    [Update... Just a few minutes later...]
    Settings -> PBX...
    "Callers who transfer out of Voicemail or other menus will be forwarded here"
    -- I can only choose a user extension, not an IVR extension. I'll need to create a dummy account....
    [ A few minutes later...]
    That may have worked. Not a good idea to test with the Android 3CX. I lost the ability to follow the traffic, but I did seem to drop my test call into perpetual music on hold. It did stop the caller from trying to bounce out to a human, though.
    #5 JCLloyd, Jan 31, 2018
