Tutorial - Fix Hold Music that is too Loud
Discussion in '3CX Phone System - General' started by noddy184, Nov 8, 2012.
  1. noddy184
    Aug 16, 2012
    22
    Hi Guys
    When I did my initial 3CX setup, I used my own WAVs for both music on hold and for menus, and the music was always too loud, and or distorted.
    I found that reducing the gain on the tracks and removing bass and treble fixed the issue.
    here is a tutorial on how to do this, which I hope will help others with this issue:
    http://youtu.be/eHQslm-dsQI
    Noddy
    MatthewHood likes this.
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Great Video Noddy - Thanks
    & Thanks too for the ninite.com reference ...
    Just wondering, do you have any prob's with leaving the audio as stereo? - as I know it's possible that Audacity can combine the channels to make it mono ...
  3. noddy184
    Aug 16, 2012
    22
    HI Graham
    Well I leave my tracks as stereo, but now you mention it, probably would make sense to change them to mono.
    All though I don't really think it is necessary.
    Yes you will love ninite, it saves hours of work every time you need to format a desktop or laptop.
    Cheers.
    Noddy
