Twilio Numbers > 3CX without SipTrunk on Twilio Side ?
Discussion in '3CX Phone System - General' started by AH2, Sep 1, 2017.
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    Is it possible to configure Twilio Numbers with 3cx Free without having to configure a Twilio SIP Trunk ? I have other vendors for that outgoing calls and Twilio does not support outgoing calls to most of LATAM countries which is our strong.
    PD: Im using 3cx Free Version thats why I can only add one SIP trunk.
    Thanks in advanced.
    AH
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Hello AH2
    No, if you req. more then one trunk then you need to upgrade to a commercial version starting from 150€/$
    AH2 likes this.
