TwiML style IVR/VAD
Discussion in 'Ideas' started by asmith3006, Mar 7, 2017.
  1. asmith3006
    Mar 5, 2014
    94
    5
    It would be amazing if there was an IVR system which would work with TwiML-style syntax (https://www.twilio.com/docs/api/twiml). This would allow a huge amount of flexibility.
    I would go so far as to say this could be an addon you can charge for or run on a separate server.
