two bpx
Discussion in '3CX Phone System - General' started by weewee9000, Jun 5, 2007.
  1. weewee9000
    Jun 5, 2007
    kindly I have 2 PBX ip system one 3cx and the other is Asterisk ,
    I can make a call from ip phone that registered in Asterisk to the ip phone registered in 3cx by option (Direct Dial ip)
    but when I make a call from ip phone registered in 3cx to ip phone registered in Asterisk by use the same option (direct Dial ip ) no respond happened
    I use Grand stream budge tone-100 ip phone .
    so what is the instruction I have to follow it to make the call ?
    Thank you
  2. weewee9000
    Jun 5, 2007
    kindly the both PBX in one lan
    i hope any one can help me,
    is there something i have to do in 3cx setting
    thank you
