Two CID's on one gateway?
Discussion in '3CX Phone System - General' started by MikeMelga, Sep 10, 2015.
  1. MikeMelga
    Mar 15, 2011
    77
    Hi.
    I use a voip provider that allows you to setup multiple caller ID's.
    I have setup 2 callerid's on the voip providers webpage. I can choose to use one or another from the voip provider webpage.
    I can setup 3CX to use one number or another but what I would really love to do is configure both numbers at the same time.
    That way I could for example use an outbound rule that would use number X.
    Is this possible? Can I configure a voip provider in 3CX to have more than 1 CallerID?
    Thanks.
    Regards,
    Mike
    11,113
    329
    I seem to recall, that the question of sending a different CID (over the same trunk group) simply by dialling a different code (prefix), has come up before and resulted in a dead end. As far as I'm aware outgoing CID is configured in one of two places, the trunk settings, and/or the extension settings within 3CX. Version 14 may be different.
  3. MikeMelga
    Mar 15, 2011
    77
    leejor,
    Thanks for the reply.
    I'll have to wait that something like that is implemented in 3cx :)
