Two debug features that would be useful
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 4, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    1. To be able to copy the text out of the debug variables when debugging
    2. If the error handler would show the attempted SQL statement if it is a database error
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Shahzad,
    Thanks for your suggestions. We're working on a new version of the VAD including many new features. We'll add your suggestions to our working list.
    In regards to the first one, have you tried copying with Ctrl+C? I tested it and works. Just open de Debug Window, go to the cell with the desired value, and press Ctrl+C. Then paste the value anywhere you need.
    Thanks,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I guess something was wrong with my CTRL-C.
