Two digital receptionists?
Discussion in '3CX Phone System - General' started by TAJ, Aug 18, 2011.
  1. TAJ
    TAJ
    Aug 18, 2011
    Is there a way in which we could have two digital receptionists on the same 3CX system.
    We currently have a digital receptionist set up for when people phone our general office number which is so far working very well... However we would like to have a second one set up which would be linked to a separate direct dial number. I.e. If somebody called that extension they would receive a different menu.
    I am fairly new to 3CX and cannot find any details in the manual about setting this up.
    Does anybody know if, firstly this can actually be done, and if so how?
    Thank you
  2. willow
    willow Member
    Mar 1, 2011
    471
    you can have as many as you want. just click on teh DR tree on the left and the add a new at the top of the page. you can then set the did to go to that DR.
  3. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I would make a flow tree on paper for what you want to do, it's a lot easier to make it happen in the PBX that way...
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    If you need any assistance in setting this up, please let me know.
