Two ideas
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jan 22, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    #1 - Whenever there is an ecmascript error it sometimes comes from the fact that you've removed a variable that something was using. It would be great if somehow the specific value of what's causing the ecmascript was part of the $CurrentErrorDescription variable in the exception handler.
    #2 - I don't know how you've built the debuging piece of the VAD, but stepping backwards would be a great feature.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Shahzad,
    Thanks for your suggestions, they are very welcome and will be definitely considered for next releases!
    The first one requires some changes to the VXML interpreter, because it does not give the detailed error information to the application, currently it only writes the error to the log. The second one can be done only changing the VAD, and I agree with you in that it will be very useful.
    Regards,
