Two New SIP Trunks Added - CenturyLink & Twilio
Discussion in '3CX Phone System - General' started by michael, Jul 6, 2017.
  1. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
  2. simonjh88
    Nov 17, 2015
    38
    I have the option to 'Download Selected', however I cannot select both of the SIP trunk updates? Why is multi-select still not a thing?
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,380
    84
    When you have only 2 Provider updates, the Select All button and multi-select is not there, when you have more than 2 updates then it becomes available.
