Two phones answer when one phone answers
Discussion in '3CX Phone System - General' started by jholcombe, Oct 7, 2015.
  1. jholcombe
    Jul 9, 2014
    79
    Two extensions 721 and 722 are members of "Ring All" ring group 951. Two virtual extensions 90001 and 90002 in a Patton PSTN gateway are set to connect inbound calls to ring group 951. Custom parameter ALLOWUSEBUSYOPTFORGROUP is set to 1, because the phones need to ring even if the the secretary is already on a call.
    Last night I upgraded from 3CX 12.5 to 14. In the process I also upgrade the firmware on all of our Yealink T46G phones to the included 28.73.0.50 firmware.
    Now if both virtual extensions 90001 and 90002 have an inbound call and the secretary on xt 721 answers a call, extension 722 also answers the same call on speakerphone, even if no-one is sitting at the desk for xt 722. It is essentially a 3-way call between the inbound caller, xt 721, and xt 722. What would cause 722 to answer the call? 722 answers the call at the exact same time that 721 does. Both phones stop ringing at that point, even though there is still another inbound caller on the other line, and ALLOWUSEBUSYOPTFORGROUP is set to 1. I don't believe we had this problem until after upgrading to 3CX v 14 and upgrading the firmware on the T46G phones.
    10,844
    299
    You might want to look over the 3CX Server logs to see what is going on. Ext 722 should obviously not be answering the call and it it is I would hazzard a guess that it is something to do with the firmware update on the set,or an option that has been enabled.
  3. jholcombe
    Jul 9, 2014
    79
    Thank you leejor! I suspect you're probably right about the firmware. I'll check over on the Yealink forums. I looked over the logs and I can't find anything obvious, but if anyone else wants to look them over please be my guest! I really need to get this resolved quickly as a deadline (for me) is approaching to have this functional and, for the most part, bug free. The log below is grouped by call #.
    06-Oct-2015 19:47:01.313 Leg L:74.1[Line:90002<<anonymous] is terminated: Cause: BYE from PBX
    06-Oct-2015 19:47:01.313 [CM503008]: Call(C:74): Call is terminated
    06-Oct-2015 19:47:01.309 Leg L:74.3[Extn] is terminated: Cause: BYE from 10.102.100.8:5062
    06-Oct-2015 19:46:48.846 Leg L:74.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:46:48.844 [CM503003]: Call(C:74): Call to <sip:722@10.102.10.1:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:46:48.731 [CM503007]: Call(C:74): Extn:721 has joined, contact <sip:721@10.102.100.8:5062>
    06-Oct-2015 19:46:48.730 [CM503007]: Call(C:74): Line:90002<<anonymous has joined, contact <sip:90002@10.102.70.1:5061>
    06-Oct-2015 19:46:48.728 L:74.3[Extn] has joined to L:74.1[Line:90002<<anonymous]
    06-Oct-2015 19:46:16.551 [CM503025]: Call(C:74): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:74.1[Line:90002<<anonymous]
    06-Oct-2015 19:46:16.547 [CM503025]: Call(C:74): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:74.1[Line:90002<<anonymous]
    06-Oct-2015 19:46:16.501 [CM503027]: Call(C:74): From: Line:90002<<anonymous (<sip:anonymous@3cx.somewhere.gov:5060>) to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:46:16.501 [CM503004]: Call(C:74): Route 1: from L:74.1[Line:90002<<anonymous] to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:46:16.500 [CM503001]: Call(C:74): Incoming call from Line:90002<<anonymous to <sip:951@10.102.10.1:5060>
    06-Oct-2015 19:47:03.645 Leg L:75.1[Line:90001<<anonymous] is terminated: Cause: BYE from PBX
    06-Oct-2015 19:47:03.644 [CM503008]: Call(C:75): Call is terminated
    06-Oct-2015 19:47:03.640 Leg L:75.2[Extn] is terminated: Cause: BYE from 10.102.100.9:5062
    06-Oct-2015 19:46:49.837 Leg L:75.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.102.100.8:5062
    06-Oct-2015 19:46:49.835 [CM503003]: Call(C:75): Call to <sip:721@10.102.10.1:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.102.100.8:5062
    06-Oct-2015 19:46:49.715 [CM503007]: Call(C:75): Extn:722 has joined, contact <sip:722@10.102.100.9:5062>
    06-Oct-2015 19:46:49.713 [CM503007]: Call(C:75): Line:90001<<anonymous has joined, contact <sip:90001@10.102.70.1:5060>
    06-Oct-2015 19:46:49.711 L:75.2[Extn] has joined to L:75.1[Line:90001<<anonymous]
    06-Oct-2015 19:46:45.575 [CM503025]: Call(C:75): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:75.1[Line:90001<<anonymous]
    06-Oct-2015 19:46:45.571 [CM503025]: Call(C:75): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:75.1[Line:90001<<anonymous]
    06-Oct-2015 19:46:45.526 [CM503027]: Call(C:75): From: Line:90001<<anonymous (<sip:anonymous@3cx.somewhere.gov:5060>) to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:46:45.526 [CM503004]: Call(C:75): Route 1: from L:75.1[Line:90001<<anonymous] to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:46:45.524 [CM503001]: Call(C:75): Incoming call from Line:90001<<anonymous to <sip:951@10.102.10.1:5060>
    06-Oct-2015 19:48:16.786 Leg L:76.3[Extn] is terminated: Cause: BYE from PBX
    06-Oct-2015 19:48:16.785 [CM503008]: Call(C:76): Call is terminated
    06-Oct-2015 19:48:16.782 Leg L:76.1[Line:90001<<anonymous] is terminated: Cause: BYE from 10.102.70.1:5060
    06-Oct-2015 19:47:33.099 Leg L:76.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:47:33.098 [CM503003]: Call(C:76): Call to <sip:722@10.102.10.1:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:47:33.076 [CM503007]: Call(C:76): Extn:721 has joined, contact <sip:721@10.102.100.8:5062>
    06-Oct-2015 19:47:33.075 [CM503007]: Call(C:76): Line:90001<<anonymous has joined, contact <sip:90001@10.102.70.1:5060>
    06-Oct-2015 19:47:33.072 L:76.3[Extn] has joined to L:76.1[Line:90001<<anonymous]
    06-Oct-2015 19:47:27.522 [CM503025]: Call(C:76): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:76.1[Line:90001<<anonymous]
    06-Oct-2015 19:47:27.518 [CM503025]: Call(C:76): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:76.1[Line:90001<<anonymous]
    06-Oct-2015 19:47:27.473 [CM503027]: Call(C:76): From: Line:90001<<anonymous (<sip:anonymous@3cx.somewhere.gov:5060>) to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:47:27.473 [CM503004]: Call(C:76): Route 1: from L:76.1[Line:90001<<anonymous] to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:47:27.471 [CM503001]: Call(C:76): Incoming call from Line:90001<<anonymous to <sip:951@10.102.10.1:5060>
    06-Oct-2015 19:48:20.486 Leg L:77.1[Line:90002<<anonymous] is terminated: Cause: BYE from PBX
    06-Oct-2015 19:48:20.486 [CM503008]: Call(C:77): Call is terminated
    06-Oct-2015 19:48:20.485 Leg L:77.3[Extn] is terminated: Cause: BYE from 10.102.100.8:5062
    06-Oct-2015 19:48:01.458 Leg L:77.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:48:01.457 [CM503003]: Call(C:77): Call to <sip:722@10.102.10.1:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.102.100.9:5062
    06-Oct-2015 19:48:01.346 [CM503007]: Call(C:77): Extn:721 has joined, contact <sip:721@10.102.100.8:5062>
    06-Oct-2015 19:48:01.346 [CM503007]: Call(C:77): Line:90002<<anonymous has joined, contact <sip:90002@10.102.70.1:5061>
    06-Oct-2015 19:48:01.344 L:77.3[Extn] has joined to L:77.1[Line:90002<<anonymous]
    06-Oct-2015 19:47:46.530 [CM503025]: Call(C:77): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:77.1[Line:90002<<anonymous]
    06-Oct-2015 19:47:46.527 [CM503025]: Call(C:77): Calling T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062] for L:77.1[Line:90002<<anonymous]
    06-Oct-2015 19:47:46.482 [CM503027]: Call(C:77): From: Line:90002<<anonymous (<sip:anonymous@3cx.somewhere.gov:5060>) to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:47:46.482 [CM503004]: Call(C:77): Route 1: from L:77.1[Line:90002<<anonymous] to T:RingAll:951@[Dev:sip:722@10.102.100.9:5062,Dev:sip:721@10.102.100.8:5062]
    06-Oct-2015 19:47:46.480 [CM503001]: Call(C:77): Incoming call from Line:90002<<anonymous to <sip:951@10.102.10.1:5060>
    Any help or advice is greatly appreciated. Thank you!,
    --John
