two TAPI services listed under phone and modems
Discussion in '3CX Phone System - General' started by t4mack, Feb 24, 2010.
  1. t4mack
    Jan 19, 2010
    56
    Can anyone tell me the difference between the two TAPI services that show up under my phone and modem. One is 3cx TAPI Service Provider (which everyone else in the office has), and the other is 3CXPSTAPI_x64.tsp. I am currently the only one who's TAPI service is not working. I think it may be using the wrong one.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Make sure that you are Admin + open command prompt with run as administrator option.
    Enter the following in cmd - (to unregister the old Tapi from the system)
    cd\
    C:\Windows\System32>regsvr32 /u 3CXPSTAPI_x64.tsp
    Then if you want you can go to Windows > System 32 and delete that file.
    >>>>C:\Windows\System32\3CXPSTAPI_x64.tsp
    Note: You need to unregister before removing the file.
  3. t4mack
    Jan 19, 2010
    56
    Sorry that didn't work. The files aren't in that location. This is a 64 bit OS maybe it stored them somewhere else.
  4. t4mack
    Jan 19, 2010
    56
    I've fixed the issue. I uninstalled the Assistant and rebooted. That removed all the TAPI services. I think the Assistant isn't fully compatible with windows 7. It works on some of the users PC at my job and on some others it doesn't. The other users' don't have anything extra installed. They all were imaged from one PC. Is there anyone that can confirm this.
