Two trunks with same Authentication ID
Discussion in '3CX Phone System - General' started by troky, Apr 6, 2018.
  1. troky
    Apr 6, 2018
    Hi all,
    My voip provider gave me access to two SBC-s (primary and backup I believe) with same login credentials (username/password) and now I can't setup both trunks in 3CX because I am getting error: "Authentication ID provided is already used for another external line - Generic VoIP Provider".
    Is there solution for this situation?
    Thanks,
    troky
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    You can't, ask if your provider can change the username for the secondary one.
    Alternatively, ask them if they have a registrar that has an SRV record, that references both primary and backup server. 3CX will work with SRV records.
    If it is a 3CX approved provider, tell me which one it is and I can try and check as well.
