Typo: Activate License Message
Discussion in '3CX Phone System - General' started by demonofsteel, Jun 7, 2010.
  1. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    It's nothing that important, but I've noticed when installing the demo key for V9 that the sentence shown after installing the license is incomplete. At least, it was on my test setup (I am using a laptop with a resolution of 1024*768 using Windows Server 2003 R2 x86 and IIS for testing).
    The sentence that I see is...
    "If you have purchased 3CX support, you should have received an email with a login and password to the 3CX Support Portal. Please contact your reseller for"
    It's missing something after the "for" at the end.
