Typo on the forum upvote page....
Discussion in '3CX Phone System - General' started by r.towle, Jun 21, 2016.
  1. r.towle
    Apr 11, 2013
    67
    10
    I some how manage to accidentally try and upvote the same thing twice, not 100% sure how - I might have had the same post open in 2 tabs - but when I click upvote again, I received this error:
    Information
    Invalid upcote
    Return to the post
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    I believe that there is a validation not allowing a user to upvote more than once, so it is very likely that you did exactly what you said, had something open in 2 tabs, upvoted once, then upvoted again on the second tab which gave this error.
    Anyhow, this is not a topic that should be in the 'Ideas' section, so moving this to General.
    * EDIT *
    I have also asked to get the typo fixed ;)
