U3 format for 3CX softphone ??
Discussion in '3CX Phone System - General' started by super_voip, Sep 5, 2007.
  1. super_voip
    Aug 29, 2007
    20
    Has anyone repackaged the 3CX softphone into a U3 format. I have a package converter but before I may have to spend many hours doing it or maybe minutes, I thought I'd check.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Haven't seen it but I like the idea. If you need a tester sign me up!
    I also need a USB handset, headset or something since my laptop doesn't have a mic on it.
  3. super_voip
    Aug 29, 2007
    20
    Done!!
    Well, it only took minutes with package factory. Now all I have to do is test.
  4. super_voip
    Aug 29, 2007
    20
    Initial testing
    Well, the 1st tests seem OK, the U3 stick holds the config, the extension works. The file is just under 1.5 Meg. Use google to find packagefactory and it's extremely easy to use, just don't copy the url file. Maybe someone will test and improve?
