UBNT edgerouter with 3cx
Discussion in '3CX Phone System - General' started by cctechguys, Feb 13, 2016.
  1. cctechguys
    Mar 25, 2009
    Hi has any one used an ubnt edgerouter with 3cx? I have client that has one and i am putting 3cx in for them. But when i hook the phones up Yealink t46g 3cx dose not see the phones. If i hook them up to another router different brand 3cx sees the phones. Just not sure if there is some setting in the ubnt router that has to be set.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Re: UBNT edgerouter and edgeswitch with 3cx
    It seems that is only possible on PoE version for 3 ports, otherwise not recommended?
