UDP bridge will not work unless you call 2 times
Discussion in '3CX Phone System - General' started by jbraun, Jan 31, 2013.
  1. jbraun
    May 16, 2012
    10
    We are having an issues with one of your udp bridges between two or our 3cx systems. the other 2 tunnels out of both end points work great, and all tunnels are set up the same way. Is this something that has been seen before as an issue with tunnel set up or do we have a network setting wrong, We have looked at both several times and can't find any reason why it would not work.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    This is not something we have seen before.
    It seems likely that you may have NAT issues of some sort. Please be aware that Port Forwarding needs to be for UDP & TCP towards the Master PBX.
  3. jbraun
    May 16, 2012
    10
    I have fixed the previous issues, but we are now getting now audio on the problem bridge. The call goes through right away but no audio from either side is delivered. I have looked in the event logs and can not find any errors or abnormalities. Any advice?
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    For a quick fix, try making a test call from Ext.A on PBX.1 to Ext.B on PBX.2 such that Ext.A and Ext.B are both set with the following parameters:
    PBX Delivers Audio: ENABLED
    Supports ReINVITEs: DISABLED
    Supports Replaces: DISABLED
  5. jbraun
    May 16, 2012
    10
    Does that also need to be set on the bridge itself or only on the ext's
  6. kevin
    kevin Member
    Nov 23, 2006
    316
    I would start by doing it on extensions AND bridge.
  7. jbraun
    May 16, 2012
    10
    Wanted to give an update on this issue. After fighting to get the UDP bridge to work to no avail, I switched the bridge to a TCP Tunnel and have had no issues since. The calls are clear and come through the first time every time
  8. kevin
    kevin Member
    Nov 23, 2006
    316
    @jbraun
    This almost certainly confirms my initial comment that it is a NAT related issue.
